Renewing a cedar closet...
BigEd
Post by BigEd »
A friend of my wife's told her that sanding the inside of a cedar closet would renew the aromatic cedar. Does anyone know if this is true? If so how much sanding is required? Sorry is this sounds dumb but not something I have ever encountered.
Thanks, BigEd
beeg
Post by beeg »
I do believe that's true BigEd. Ya need to sand it enough to refresh the surface. Hope ya have a belt sander.
efmaron
Post by efmaron »
Ed,
Yes sanding aromatic cedar will renew the aroma with just a little sanding. BUT WEAR A VERY GOOD DUST MASK, AROMATIC CEDAR IS TOXIC. Remove everything from the closet and vacume the dust up often. With that said the cedar is still doing its job as a insect deterrent even if you do not smell the aroma.
Eric, Sebring Fl.
If it were mine I'd try hand sanding first. With a sanding block and 150 grit, followed by 220 grit. This should be enough. Yes, it will bring back the aroma.
a1gutterman
Post by a1gutterman »
Very light sanding has worked for me.
Tim
