Table Saw Blade replacements
tbinggeli
Post by tbinggeli »
Can you guys tell me if you can buy any other replacement table saw blade than the Shopsmith brand? I'm looking for a quick replacement and I hear ordering from Shopsmith can take months.
Thanks!
beeg
Post by beeg »
As long as ya can find one with a 1 1/4 arbor hole.
navycop
Post by navycop »
beeg wrote:As long as ya can find one with a 1 1/4 arbor hole.
Can it be any size or does it have to be 10" to fit?
Mark V 520, Ryobi 12" mitersaw, Delta 10" tablesaw, DC 3300.
navycop wrote:Can it be any size or does it have to be 10" to fit?
10" or less. A smaller blade decreases the maximun depth of cut.
RE 1 1/4" arbor hole. 5/8" arbors are available from ss for use with more common blades with 5/8" arbor holes.
a1gutterman
Post by a1gutterman »
tbinggeli wrote:Can you guys tell me if you can buy any other replacement table saw blade than the Shopsmith brand? I'm looking for a quick replacement and I hear ordering from Shopsmith can take months.
Thanks!
To summarize: Any 10" (or smaller:eek: ) blade with either a 1 1/4" or a 5/8" hole will work. They do knot have to be ShopSmith, but you do need either the 1 1/4" or the 5/8" SS sawblade arbor to fit the appropriate blade.
BTW, where did you hear that? Call to place your order and ask if the blade is available now. Or if the saw arbor is available now.
Tim
navycop
Post by navycop »
What is the metric for 1 1/4? I think 5/8 is .675.
joedw00
Post by joedw00 »
tbinggeli
Welcome to the forum. You will need this to use with the more common blades with 5/8" arbor holes.
http://www.shopsmith.com/ownersite/cata ... arbors.htm
Joe
Being a VETERAN is an honor
Being a GRANDPA is priceless
Thanks!
There have been times when the delay receiving parts was unacceptable but generally that has not been my experience.
That said, if you are going to use a standard 10" saw blade, you need one of these.
http://www.shopsmith.com/ownersite/item ... =Find+Item
I don't recommend any other substitute for this.
Thanks!
navycop
Post by navycop »
joedw00 wrote:tbinggeli
This arbor looks different than the one in Dusty's link.:confused:
