Mark V variable speed dial binding
cybersspot
Post by cybersspot »
I just received my 1985 shopsmith that I won on Ebay, the only problem is the variable speed dial is binding towards the fast and slow speeds. I'm guessing it just needs a cleaning/lubricating job done to it. How do I remove that dial to freshen it up?
cybersspot wrote:I just received my 1985 shopsmith that I won on Ebay, the only problem is the variable speed dial is binding towards the fast and slow speeds. I'm guessing it just needs a cleaning/lubricating job done to it. How do I remove that dial to freshen it up?
I think you might want to view this Sawdust Session.
http://www.shopsmithacademy.com/SS_Arch ... _Index.htm
There are some others here that are well worth viewing too.
I hope it was 'running' when you turned the dial! :eek:
Here is another sawdust session you NEED to review!
http://www.shopsmithacademy.com/SS_Arch ... enance.htm
cincinnati
Post by cincinnati »
Welcome!
Here are a list of sawdust videos that will get you started.
Any other help, Just ask.
http://www.shopsmithacademy.com/Sawdust_Sessions.htm
This link will get you the answer to your question. Look at about the 12 min mark
http://www.shopsmithacademy.com/SS_Arch ... rn_Pt2.htm
cybersspot
Thank you
I watched the videos at work here (without sound) and it looks like it's exactly what I need to do. Thanks, Dave
cybersspot wrote:I watched the videos at work here (without sound) and it looks like it's exactly what I need to do. Thanks, Dave
The 'sound track' contains much useful information!
