Cleaning pitch off Saw blades
Got some dirty, clogged blades and bits. What do you use to clean them?
SS MV 520, bandsaw, jointer, planer, belt sander, mortise unit, biscut jointer, speed reducer, tool rest upgrade, sliding cross cut table, DC3300
Use cheap spray oven cleaner. Just WATCH OUT for the smell.
I worked through that issue several weeks ago. what a mess. Since then I purchased the only simple and effective solution I have managed to find. Check it out for yourself:markap wrote:Got some dirty, clogged blades and bits. What do you use to clean them?
http://www.rockler.com/product.cfm?page ... ning%20kit fjimp:)
F. Jim Parks
Lakewood, Colorado:)
I tried that stuff. It works to a limited degree. The fumes are enough to inhibit ones breathing and the elbow grease required could wear an old guy out. I like the idea of depositing the blade into a closed container and allowing the cleaner to break down pitch naturally. fjimpmickyd wrote:Internet says "Simple Green" concentrate is the way to go. I have no idea but that would be my first approach.
F. Jim Parks
recurvearcher
The Wood Whisperer demonstrated the Rockler cleaning kit (and warns against oven cleaner) in one of his videos.
http://thewoodwhisperer.com/episode-28- ... t-settles/
The actual demo starts at the 4 minute mark. The pan he is using looks exactly like the cheap pan I got at Walmart for changing the oil in my truck.
wgander
cleaning saw blades
I've been satisfied with oven cleaner. I let it sit for a few minutes and then wipe the blade with a green 3M pad. A thorough rinse with fresh water and towel dry: blade looks new.
The video says caustic stuff can weaken the bond of carbide tips but cites no facts and I don't know if there's any truth to that.
