Crosscut Sled
Crosscut Sled
I'm curious what everyone uses for a cross cut sled. Are most of the Mark V users sticking with the Shopsmith sled or are you migrating to something else. If so, what?
I've modified mine a little and plan to stick with it.
[ATTACH]6201[/ATTACH]
[ATTACH]6202[/ATTACH]
[ATTACH]6203[/ATTACH]
[ATTACH]6204[/ATTACH]
- PA160026 (Small).JPG (38.82 KiB) Viewed 13289 times
- PA160025 (Small).JPG (41.04 KiB) Viewed 13256 times
- PA160027 (Small).JPG (36.61 KiB) Viewed 13337 times
- PA160028 (Small).JPG (42.43 KiB) Viewed 13267 times
Dusty,
Most of my crosscut work is done with the shopsmith sled. I also have have modified mine after taking part in Nicks sawdust sessions. I find it is as versatile and accurate as any other option I have tried. fjimp
F. Jim Parks
Lakewood, Colorado:)
I don't have a crosscut sled, why would one need one?
Don't need or use a crosscut sled! I have a panel sled, that is about the same thing, but that's for panels, not boards.
The way I look at it - The Shopsmith miter gauge with an extension is very ample for any board that I'll use.
- a1gutterman
- curiousgeorge
Appalachian and a couple of home brew ones(nothing fancy)!
I use one I made.dusty wrote:I'm curious what everyone uses for a cross cut sled. Are most of the Mark V users sticking with the Shopsmith sled or are you migrating to something else. If so, what? I've modified mine a little and plan to stick with it. [ATTACH]6203[/ATTACH]
Dusty, I really like that zero clearance insert. Did you buy or make it?
Mark V 520, Ryobi 12" mitersaw, Delta 10" tablesaw, DC 3300.
