need help
dave_dr_david
- Bronze Member
need help
I just aquired a Mark V from my grandfather. I am trying to to figure everything out on it but seem to be having difficulties setting up the bandsaw that came with it. It seems I am missing a part that connects the bandsaw to the motor. It looks like a sleeve of some sort should be used. Does anyone know what this is called so I can order the part.
- tom_k/mo
What you need is the Powercoupler. The side with the spring always connects to the headstock.
dave_dr_david wrote:I just aquired a Mark V from my grandfather. I am trying to to figure everything out on it but seem to be having difficulties setting up the bandsaw that came with it. It seems I am missing a part that connects the bandsaw to the motor. It looks like a sleeve of some sort should be used. Does anyone know what this is called so I can order the part.
I think this is what you need.
http://www.shopsmith.com/ownersite/part ... tslist.htm
This is just the coupler.
http://www.shopsmith.com/ownersite/item ... =Find+Item
You will need these if you don't have them:
dave_dr_david
- Bronze Member
thanks
thanks for the info guys
