Nick's sandpaper & glue-up video
cincinnati
Post by cincinnati »
Anyone know where exactly I can find the video of Nick showing how he uses grit off sandpaper to keep glue-ups from sliding around?
And yes I did look but can't find it.
lv2wdwrk
Post by lv2wdwrk »
cincinnati wrote:Anyone know where exactly I can find the video of Nick showing how he uses grit off sandpaper to keep glue-ups from sliding around?
Try this link
http://www.shopsmithacademy.com/Tips_Ar ... ue_Tip.htm
cincinnati
Thats the one. Thanks!
cincinnati
lv2wdwrk
Post by lv2wdwrk »
One thanks is enough. Glad I could help.
a1gutterman
Post by a1gutterman »
I am glad that Bob was able to find that for you: Some woodworkers have expressed concern that the sand Nick added to the glue could help dull saw blades and router bits prematurely. If this concerns you too, you could substitute ground walnut shells for the sand.:)
Tim
tryinhard
Huh?
Post by tryinhard »
I can understand the concern over dulling due to hitting the grains of sand. But won't there must more dulling due to passing through all the hardened glue that surrounds the few grains of sand?
tryinhard wrote:I can understand the concern over dulling due to hitting the grains of sand. But won't there must more dulling due to passing through all the hardened glue that surrounds the few grains of sand?
Perhaps(depends on how hard the glue has set). I do not think that procedure adds enough 'grits' to be concerned about. If you intend to do much cutting through an area, limit the 'grits' to someplace else.
This is probably Not a good idea if gluing for later 'turning'.
