Member johnmccrossen was looking for a close up photo of the Greenie sawgaurd bracket so that he could recreate. I figured it was worth posting in the event that someone else out here might want to do the same.
In addition to the photo, there is a pdf file, created to scale, that can be printed out and used as a tracing template. The pdf paper size is set to ledger (11" x 17") so unless you can print that size, it may be a run down to Office Depot / Staples / Kinko. If you print out the image on 8-1/2" x 11", you'll have to up scale it using whatever method your comfortable with. The forum can suggest several methods if you need help.
[ATTACH]6457[/ATTACH]
[ATTACH]6458[/ATTACH]...[ATTACH]6459[/ATTACH]
[ATTACH]6462[/ATTACH].
Here's the pdf file:
[ATTACH]6463[/ATTACH]
Greenie Upper / Lower Sawgaurd and Bracket Photos
- mickyd
- Img_7482mod1.jpg (168.5 KiB) Viewed 6390 times
- Img_7571mod.jpg (71.02 KiB) Viewed 6389 times
- Img_7572mod.jpg (85.19 KiB) Viewed 6383 times
- Img_7570mod.jpg (194.43 KiB) Viewed 6393 times
Saw guard bracket.pdf- (972.45 KiB) Downloaded 991 times
Sunny San Diego
Sunny San Diego
Really a helping hand to some!
Wow!!! Mike - That is a cool post!
- johnmccrossen
Mickyd: Double the wow! Thanks for your pictures and pdf file. All of the pictures and printed literature that I have seen for the early Model 500 aluminum metal guards show a stamped metal bracket between the lower guard and the splitter plate. This must be the original earlier version. I find it fascinating to keep learning more about the Mark V evolution. Thanks again for taking the time to set up and share this. John McCrossen
John McCrossen
Everett, Wa.
1954 Mk 5 SN 269454, 1955 Mk 5 SN 316013, 1960 Mk 5 SN 360792, 1962 Mk 5 SN 380102, Magna band saw, (2) jointers, (1) belt sander, (1) air compressor, (1) jig saw, (1) strip sander, (1) 20" scroll saw, DC 3300 dust collector, Sawsmith RAS, Craftsman table saw, 13" DeWalt planer, Triton 3 1/4 HP plunge router & table
Everett, Wa.
Whats with the 9 inch tape measure?:D REF: post #1, pix 4.
Closer examination reveals the crop line in the blackness! Ah So!mickyd wrote:I'm a cropper!! (and it's 8-3/4"....)
