Mortised Reel Seat
nebraska
Mortised Reel Seat
Post by nebraska »
Forgive my ignorance here, but I'm nearing completion on a bamboo fly fishing rod and I don't know the best way to create the mortise on a real seat I turned with my ShopSmith.
Can someone help me out?
Here is what I'm going for...
(The mortise is used to accept the real foot - one end of the reel foot slides under the cap and the other end is secured with the ring)
-Chad
1982 SS ~ Bandsaw, Jointer (Inherited in 2008, Restoration in Progress)
Primary Project ~ Making bamboo fly rods (View Complete Project Blog)
horologist
Post by horologist »
Chad,
For a one off, you could try a custom scratch stock with a body that matches the diameter of the handle and a blade that has the correct contour for the mortise.
Take a look at this video for some ideas on how to make one.
http://www.finewoodworking.com/SkillsAndTechniques/SkillsAndTechniquesArticle.aspx?id=31290
If you plan on making a bunch of these then I have an idea for a jig but this is a bit more complicated.
Troy
nebraska
Post by nebraska »
Thanks Troy. I plan to make a few of these per year for a long time to come. :)
-Chad
easterngray
Post by easterngray »
Hi Chad - the mortise on the reel seat is done with a fingernail router bit. I also make bamboo fly rods and the shopsmith is a great tool for the rodmaker! here is a link for the bit:
http://www.grizzly.com/products/c1215
Alec
nebraska
Post by nebraska »
Thanks Alec!
This is my first rod and after two years, I'm finally on the home stretch. I certainly could not have gotten this far without the ShopSmith.
I'd love to see some of your finished rods if you have a site/pics.
-Chad
easterngray
Hi Chad,
This is the only picture I have presently. This is a 7.5' 5 wt., 1 tip, with a nickle silver and butternut reel seat and a cigar grip. The wraps are red and black varigated. (no guides yet in this picture). I use Helmsman spar varnish for the finish - brushed on. I also made the net. It is sycamore with a walnut swoop through the handle.
I use the Shopsmith to rough bevel with a router bit and hardwood preliminary form. It is a very slow process due to the speed of the shopsmith. As always - light cuts and slow feed. I am really looking forward to getting a new Power Pro headstock when available. I am going to start cutting my strips on the bandsaw as well, rather than hand splitting. I know that some makers have had good success with this, but I just haven't built the jig yet. I also turn the cork handles on the Shopsmith. God bless and good rod making! Alec
nllaeder
Post by nllaeder »
Do you also turn ferrule stations on the Shopsmith?
I just glued up my first blank on Saturday, and have been looking for a Shopsmith for a while. I may have found a candidate last night. I'm trying to go look at it tonight.
easterngray
I do the ferrules by hand, but if I had a set of Dave Leclairs ferrule station cuttersI think it could be done on the Shopsmith.
The Shopsmith is a fine tool for the rodmaker - let us know how you make out! Alec
