Woodsmith Videos
- curiousgeorge
Woodsmith Videos
I'm sure some or most of you are familiar with the Woodsmith videos at Woodworkingonline.com, so I thought you might be interested in an index to the different videos that are available. So far there are 42 covering all aspects of wood working and it is a real pain trying to go back through all of them to find one in particular. I made a PDF index and, if it works correctly, and if you are on line, all you have to do is click on the video you want in the index and it should open in your browser. Even if it doesn't work, at least you will still have the index to reference.
Woodsmith Video Index.pdf- (46.05 KiB) Downloaded 1144 times
George
Ft. Worth, TX.
Go TCU Froggies
Ft. Worth, TX.
Go TCU Froggies
THANKS George for the index. It works for me.
Check out a free program called "Primo PDF." It installs as a printer. When you want to turn a document into a PDF file, you "print" it but you choose "Primo PDF" as the printer. The program will walk you through the rest. It's easy and free.nomoman wrote:Works for me.. I wish I knew how to do that (pdf files). It would come in handy for other stuff.
Heath
Central Louisiana
Central Louisiana
- mickyd
Does it let you insert hyperlinks in the pdf?heathicus wrote:Check out a free program called "Primo PDF." It installs as a printer. When you want to turn a document into a PDF file, you "print" it but you choose "Primo PDF" as the printer. The program will walk you through the rest. It's easy and free.
Sunny San Diego
Sunny San Diego
- curiousgeorge
I use a free program called OpenOffice. I couldn't afford MS Office so I downloaded this program. It reads and writes MS Office files and does just about anything MS Office can do. Including Saving a file in PDF format. If you are in need of a good "Office Type" program, you can't go wrong with this one... http://www.openoffice.org/
George
Ft. Worth, TX.
Go TCU Froggies
Ft. Worth, TX.
Go TCU Froggies
I second this opinion.
curiousgeorge wrote:I use a free program called OpenOffice. I couldn't afford MS Office so I downloaded this program. It reads and writes MS Office files and does just about anything MS Office can do. Including Saving a file in PDF format. If you are in need of a good "Office Type" program, you can't go wrong with this one... http://www.openoffice.org/
