Gift for Grandgirls
kalynzoo
Gift for Grandgirls
Post by kalynzoo »
Walking through the stores I found the grandgirls were crazy for NewMoon, the vanpire movie. I pulled up a logo on the web and used it as the pattern. I'm told by my daughter that this will make great Christmas gifts. Oak on 1/4in ply
[ATTACH]6875[/ATTACH]
Twilight New Moon resized.jpg (93.82 KiB) Viewed 1818 times
Gary Kalyn
Kalynzoo Productions
Woodworking
Porter Ranch/Northridge
Los Angeles, CA
a1gutterman
Post by a1gutterman »
Looks good, Gary. Scroll saw? Jig saw? Both?
Tim
cocacola1012
Post by cocacola1012 »
So you cut out the pieces individually? How did you get "cullen" on the bottom?
Thanks from a novice... I hope I can fill your shoes someday.
PS Great job.
kalynzoo
Post by kalynzoo »
cocacola1012 wrote:So you cut out the pieces individually? How did you get "cullen" on the bottom?
I have a Hawk scrollsaw, though brand in not important. I drilled starting holes with a #70 drill bit and then used a #1 scrollsaw blade to make the cuts. Each project used 2 blades as the heat from oak dulled and blackened the blade, even at slow speed. The letters are cut with inside cuts, nibbling at the corners to keep them sharp. The entire project is cut as in "inside cut", leaving a frame for support until the last minute. First cut the little pieces, then cut the top filigree, finally cut the sides and bottom, always leaving as much wood as possible for support.
Enjoy your scrolling.
Gary Kalyn
Woodworking
Los Angeles, CA
kalynzoo wrote:Walking through the stores I found the grandgirls were crazy for NewMoon, the vanpire movie. I pulled up a logo on the web and used it as the pattern. I'm told by my daughter that this will make great Christmas gifts. Oak on 1/4in ply
Very Nice Work!
What are the over all dimensions
Gary - I am always wowed with your skill. --- Just WOW!!!! It is plain to see that a beginner in scroll saw work, like me, would have to draw on other's experience to figure out how to do something like this. I'm guessing you acquired your knowledge and skills with all of your intarsia work! One of the best things about this type of work is you can do it even with physical restrictions! GREAT WORK!!!!
I'm sure your grandgirls will love this!
john
Post by john »
Gary:
Great work! Besides the finished project, I admire the patience it must have taken to do all that detail and inside cuts.
I'm sure the young ones will be happy.
John
