Does anyone have information or the procedure for checking the motor bearings? I have an older Mark 5 500 with an AO Smith 1 1/8HP motor (Model C48L2A16). I have never had a motor apart, so I'm looking for help removing the sheaves and what I need to take apart to check the bearings. Hopefully I can find part numbers on the bearings to find replacements if needed.
I have the headstock torn down and I'm working on replacing the quill and drive sleeve bearings.
Thanks!
Loren
Motor bearings
- mickyd
Good bearings will not free spin. There should be resistance from the grease inside. They should not make any sound or feel when you rotate them by hand.hobbydad wrote:Does anyone have information or the procedure for checking the motor bearings? I have an older Mark 5 500 with an AO Smith 1 1/8HP motor (Model C48L2A16). I have never had a motor apart, so I'm looking for help removing the sheaves and what I need to take apart to check the bearings. Hopefully I can find part numbers on the bearings to find replacements if needed.
Thanks!
Loren
Sunny San Diego
Sunny San Diego
Here is a nice set of service references:hobbydad wrote:Does anyone have information or the procedure for checking the motor bearings? I have an older Mark 5 500 with an AO Smith 1 1/8HP motor (Model C48L2A16). I have never had a motor apart, so I'm looking for help removing the sheaves and what I need to take apart to check the bearings. Hopefully I can find part numbers on the bearings to find replacements if needed.
Thanks!
Loren
http://allinonewood.com/?page=shop/serviceadvisor&
I have seen more than one motor assembly from the early '80s with a warped fan-sheave. Once you get to that level (taking off the big spring, etc.) then you might as well get a new sheave-spacer just in case, and a new lock-screw for the fan sheave.
As a rule the motor bearing nearest the sheaves will wear out faster than the other bearing.
Good luck!
Chris
