Jointer Question
mandoboy
Jointer Question
Post by mandoboy »
The fence on my jointer does not lock into place on the fence mounting bar.
Does anyone know if there is supposed to be a dowel pin (506721) in the hollow threaded rod in the quadrant assembly (502651) that pushes against the fence when the sleeve screw (506720) is tightened.
I hope that makes sense.
Thanks.
JeffG
james.miller
Post by james.miller »
Try Ref # 46 Dowel Pin # 506721, it pushes against the Fence Mounting Bar to lock it in place. You could probably buy something close enough at Ace Hardware then saw and grind it to length
Jim in Tucson
mandoboy
Post by mandoboy »
Thanks Jim. I thought that was how it worked. My old 1956 jointer works great except that I can't lock the fence in place. Now I know why.
JeffG
