First generation compressor diaphragm
easterngray
Post by easterngray »
Does anyone know where I could get a new diaphragm for a first generation Magna compressor? I imagine I could make one myself if I can come up with the proper material. It is fabric reinforced rubber material. Thanks - Alec
UPDATE: I found 3/32" fabric reinforced neoprene diaphragm material in 12" x 12" sheets for under 7 bucks at McMaster Carr. Alec
a1gutterman
Post by a1gutterman »
easterngray wrote:Does anyone know where I could get a new diaphragm for a first generation Magna compressor? I imagine I could make one myself if I can come up with the proper material. It is fabric reinforced rubber material. Thanks - Alec
I am glad that you found something that will work for you, Alec!
Tim
easterngray
Thanks Tim - I fired up my Magna compressor today in order to prime the doors I just built and it sounded like it was giving me a "Bronx cheer". :eek:
I opened it up and discovered that the diaphragm had a long tear in it - dry rot I suppose. Shouldn't be hard to fix. In the meantime, I broke out a brush to prime the doors. Effective, but not nearly as fun as painting with a Mark V! Alec
easterngray
I received the material from McMaster Carr and fabricated a new diaphragm. The 3/32" material is thicker than the original diaphragm and the compressor now works better than ever - but man is it LOUD :eek:
If anyone out there has a compressor that needs a new diaphragm feel free to PM me as I have plenty of material left over to make more.
Here it is on the Goldie...
MAGNA COMPRESSOR
a1gutterman
easterngray wrote:I received the material from McMaster Carr and fabricated a new diaphragm. The 3/32" material is thicker than the original diaphragm and the compressor now works better than ever - but man is it LOUD :eek: ...
Do knot forget to wear hearing protection!:)
Tim
