ER10 upper belt pulley ID / mating shaft OD
mickyd
Post by mickyd »
Anyone know what these parts should measure?
  • ID of the upper belt pulley
  • OD of it's mating shaft
My ER pulley ID is .825" / mating shaft OD. 810". (.015" difference).:eek:
Sunny San Diego
SDSSmith
Post by SDSSmith »
From memory, 13/16" pulley bore.
Rob in San Diego
Good luck finding a 0.0075 thick sleeve!:D A pop can about twice around oughta do it!:rolleyes:
SDSSmith
Post by SDSSmith »
Again from recollection, the headstock pulley was non-standard and required a standard bore pulley to be bored out to 13/16". Man, I hope I 'membered correctly.
Rob in San Diego
mickyd
Post by mickyd »
JPG40504 wrote:Good luck finding a 0.0075 thick sleeve!:D A pop can about twice around oughta do it!:rolleyes:
Soda can WILL be the solution. Here's a photo of what the shaft looks like. I would think the previous owner would have realized there was an issue before it reached this state.:(
[ATTACH]7322[/ATTACH]
Sunny San Diego
heathicus
Post by heathicus »
mickyd wrote:Soda can WILL be the solution. Here's a photo of what the shaft looks like. I would think the previous owner would have realized there was an issue before it reached this state.:(
Well, it was painted orange which calls the previous owner's observational skills into question to begin with...
Heath
Central Louisiana
