Mistakes in the shop
mbcabinetmaker
Post by mbcabinetmaker »
Hey that was right the first time I cut it wrong!:D :) :p
That was my exact thought while I was re-cutting some door rails today. I was setting up a new set of rail and style cutters and needed to modify my math by 1/8 inch. Problem was I added 1/8 instead of subtracting. 80 door rails were 1/4 inch to long when I began to assemble. At least I could cut them down. The very first 4 should have been 4 inches long. While re-cutting them I realized that I had miss read the stop tape this morning and had actually cut them wrong (3.75 inches) and tossed them and re-cut at 4 inches. Now 4 - .250 = 3.75 so they were actually right. Confused? :confused: Me to, it has been a long day.
Mark
2017 Power Pro Mark 7
robinson46176
Post by robinson46176 »
mbcabinetmaker wrote:Hey that was right the first time I cut it wrong!:p
See my signature... :D
Post by ------------------------ »
I hate when that happens. I do a lot a installing of new cabinet hardware and it really makes me nervous knowing one wrong hole could cost me a wad of $$$$$$$$$$$$$$
Mark
mbcabinetmaker
mark-b wrote:I hate when that happens. I do a lot a installing of new cabinet hardware and it really makes me nervous knowing one wrong hole could cost me a wad of $$$$$$$$$$$$$$
Mark
I once drilled a high gloss laminate door on the wrong side. I was working 6 hrs from home and rushing to finish a job before grand opened the next morning. I forgave myself because it was 4:00 am and I had been there for 22 hrs straight.
Mark
kalynzoo
Post by kalynzoo »
And then there was the time I was mounting hardware on a fully mirrored sliding closet door. The screw was just a fraction too long. The mirror was unforgiving.
Gary Kalyn
Kalynzoo Productions
Woodworking
Porter Ranch/Northridge
Los Angeles, CA
shipwright
Post by shipwright »
How many of us have made two right (left) hand sides for step stools, drawer sides, etc.? more than once? often?
Me too
Paul M
cv3
Post by cv3 »
Trying to install a new bath room sink in to the hole I cut using the measurements I had written down from the old sink that was a1/2 bigger around. Talk about falling though your hole.
Make today a day that lets you smile!
CV
Mobile Al.
MARK V 520 - Band saw and Jointer. DeWalt scroll saw.
cv3
Post by cv3 »
Trying to install a new bath room sink in to the hole I cut using the measurements I had written down from the old sink that was A 1/2" bigger around. Talk about falling though your hole.
CV
Mobile Al.
fjimp
Post by fjimp »
cv3 wrote:Trying to install a new bath room sink in to the hole I cut using the measurements I had written down from the old sink that was a1/2 bigger around. Talk about falling though your hole.
I still remember my wife watching me measure a sink hole from a counter top I had just removed and transfer the measurements to the new counter top. As I was preparing to cut the hole she suggested I just may want to measure the new sink first. She saved me dollars and a lot of blue air. Jim
F. Jim Parks
Lakewood, Colorado:)
dlbristol
Post by dlbristol »
I very carefully laid out the arms on a rocker I was making. Left to the left, right to the right, then carefully laying each arm down, I turned them over and glued the side assemblies on. As you guessed, when turned back over right side up, glue set and there to stay, I discovered the arms are on backwards.:mad: Right on left ect. I considered using this as "design opportunity" but realized quickly that with the model chair in the same room, someone might ask, so I cut them off and installed them correctly. Some where there is a post about how to get the arms off the sides.:o
Dave
