Quill Spring
ozarkboy2
Quill Spring
Post by ozarkboy2 »
Any advice before I get started??? My quill return spring dosen't work. 'm going to try too get it apart to see if the spring is broken, or maybe a previous owner worked on it and didn't wind it back tight.
Was wondering if there was/is a heads up on doing this????
Heath thanks again for the Spure Center, it looks like it hasn't been used. Did you get the card I sent?
Post by ------------------------ »
Try this first:
With machine laying down, loosen the quill lock and remove depth stop nuts. Run quill all the way down, it will stop coming out as it reaches the end. As you continue turning the quill feed lever, do you feel spring tension building? If yes then build a little more tension and then manually push quill into headstock while briing feed lever backwards. You may reach a point where you have to hold pulley and turn spindle by hand to get the splines to line up. When they line up, the spindle will snap into headstock-watch your fingers and let go!!
Mark
heathicus
Post by heathicus »
I'm guessing the spring has come unhooked from the shaft.
The quill springs on each of my ER's were packed with sawdust and oil and crud. I didn't find it difficult at all to remove, clean, and reassemble them. I can't really explain the process because I've slept a few times since then.
Glad you're happy with the spur center. And yes, I did get the card. Thank you!
Heath
Central Louisiana
kameljoe21
Post by kameljoe21 »
i have the same problem
but up till now i have just let it slide till some one else posted the problem
but i think that it was due to me removing the quill lock and messing with the head stock when i first got it
so now i know what to do
i did have a problem in the beginning trying to put the quill back in but a flash light and some pondering i was able to see how the whole inards work and now have a great sence for the simpleness that it has
http://s853.photobucket.com/home/kameljoe21/allalbums
194X Spiegel 4.5" Jointer M600 NO460
1947 ShopSmith 10E S#9074
1957 McCulloch 55 Chainsaw
1955 Mall General Purpose Chainsaw
1952 Farmall H S#368935
1985 Honda 125M ATC
2006 Honda CRF 50 F
1978 Packard Drill Press M#120F-IND
195x Delta Table Saw S#AY4575
1997 Craftsman Chipper M#247797851
1982 Ariens Snow Blower M#ST504
194x Duro 30" Scroll Saw S#B07132PL
194x John Deere #5 Sickle Mower
19xx Antique Modified 3PT Hay Rake
