Quick Cradle for Strip Down
PG-Zac
Post by PG-Zac »
I started stripping my Goldie today, so I knocked this cradle together to support it while working.
I rough cut the base and overlong uprights. I then clamped the uprights together and used a large Forstner to drill the support cut-outs and cut off the tops off the uprights to give me half-round cradles for the way tubes. A few angle brackets later all glued and screwed, and I have a good work stand.
I can even turn the unit on its side to access the underside.
wannabewoodworker
Post by wannabewoodworker »
WOW..............:eek: I thought my Mark VII was in bad shape. You really have your work cut out for you. Good luck but when it is finished you will be very pleased.
Michael Mayo
Senior IT Support Engineer
Soft Designs Inc.
albiemanmike@gmail.com
1960's SS Mark VII, 1954 Greenie, 1983 Mark V, Jointer, Bandsaw, Jigsaw, Dewalt Slider, Delta Super 10, Delta 8" Grinder, Craftsman compressor, Drill Doctor, Kreg PH Jig, Bosch Jigsaw, Craftsman Router and Table...........and adding more all the time....:D
