Saw blade alignment
swampfox22
- Bronze Member
Saw blade alignment
Just purchased a used 1999 Mark 5 Model 510. I'm having trouble getting the saw blade aligned with the bottom guard. It is rubbing against it unless I move the arbor out about 3/16 of an inch on the drive shaft. I know, not suppose to do that. Aligning the table is not a problem. I'm sure it is the proper 5/8 arbor for the 510. Any ideas?
It sounds like you are attempting to use an arbor designed for the 500s. It is shorter than the 510 arbors. However, you can extend the quill to position the blade so that you can use this arbor.swampfox22 wrote:Just purchased a used 1999 Mark 5 Model 510. I'm having trouble getting the saw blade aligned with the bottom guard. It is rubbing against it unless I move the arbor out about 3/16 of an inch on the drive shaft. I know, not suppose to do that. Aligning the table is not a problem. I'm sure it is the proper 5/8 arbor for the 510. Any ideas?
I would not extend the arbor far and use with a saw blade but to position within the insert is in my opinion acceptable.
Is this the arbor you have?
http://www.shopsmith.com/ownersite/itemfind.htm?item=555130&Submit=Find+Item
swampfox22
- Bronze Member
swampfox22
- Bronze Member
swampfox22
- Bronze Member
Nope mine is a 5/8. Have ordered a new one from SS.beeg wrote:Is this the arbor you have?
