Zero Clearance Insert
Hi All,
I broke the plastic zero clearance insert on my 510 today. I was thinking about making my own.
Has anyone made their own and, if so, what thickness and kind of wood did you use?
Brent
Brent
- a1gutterman
Hi Brent!tnerb wrote:Hi All,
Brent
ZCI's in my shop need replacing periodically. The more you use them, the less they are zero clearance.
Tim
I found some hardboard sheets at Home Depot that happen to be just the right thickness. I laid the table inserts on top and traced out the shapes and hole positions. A few rip cuts to width, cut the curves with the band saw, a little clean up with the sanding disk, drill and counter sink the holes. Works for me.
Jim Ramsey
Lakewood, CA
"When people find out that my hobby is woodworking, they often ask what do I do with it. I tell them that I am very good at making sawdust and expensive firewood."
Lakewood, CA
cincinnati10
Brent
I made mine out of 1/4 inch phenolic. It's dead flat, and doesn't change with humidity. Using double-sided turning tape (carpet tape) attach the old one to the slightly oversized blank. Run it through the router table with a flush cut bit adjusted high enough so that the bearing will ride on the template and the flutes will not hit the template.
I bought a sheet of 1/4" x12 x12 phenolic from amazon for something like $13.00
I made 3 today out of 1/4" MDF from HD that really wasn't 1/4" so it sat low in the table. Ended up shimming the edges with pre glued veneer edging. It's fairly even all around now. Sprayed in with some red paint I had hanging around the shop. Almost looks like the real thing.......
Tomorrow, I'll install it and make the saw slot.
Brent
Brent
Once done, you will have the real thing and it is home made in your own wood working shop. I think that is neat.tnerb wrote:I made 3 today out of 1/4" MDF from HD that really wasn't 1/4" so it sat low in the table. Ended up shimming the edges with pre glued veneer edging. It's fairly even all around now. Sprayed in with some red paint I had hanging around the shop. Almost looks like the real thing.......
Brent
You do want to ascertain that the insert rides level with the table surface.
My perception of NM does not include either cold or rainy!;)tnerb wrote:Well, today was kinda cold and very rainy. Since I like to work out on the pad in front of the shop, I'll try tomorrow to cut the slot.
I did manage to start glue up on one of my projects tho, so it wasn't a total wasted day.
Brent
