I decided to turn some Pens using wood from my BIL's fallen Live Oak. The pens were preceded with some bowls that displayed some desirable properties. The Pens used offcuts from the raw wood, are my first pen turnings, used SS accessories and SWAG Stff We All Got) instead of pen mandrel kit.
The download executable contains the article, browser, links, and pictures. YOUR ISP, TRANSFER UTILITY, OR FIREWALL SHOULD PROTECT OR DETECT VIRSUSES, MALWARE, SPYWARE, ETC IN EXECUTABLES. The executable is used to keep pictures and links available in a single file, of 4.11 MB w/o reducing the picture size or losing the links in a PDF.
1st Pens Turned Using SWAG SShopSmith Accessories
MK V 520; MK V 510 w/PP DIY Upgrade; MK 5 500; Jointer; Bandsaw; Sliding Table; Conical Sanding Disk; Sharpening Guide, Lathe Duplicator, Jigsaw, Scrollsaw, Beltsander, Ring Master, Biscuit Joiner.
I'd love to see it, but I'm not about to download an unknown executable. A PDF of larger file size would be preferable (you can have web links in a PDF file). Or upload the pics here or to Photobucket.
Heath
Central Louisiana
Central Louisiana
...and your elected federal officials should uphold the Constitution (as they are sworn to do),:(allsas wrote:The <link deleted> contains the article, browser, links, and pictures. YOUR ISP, TRANSFER UTILITY, OR FIREWALL SHOULD PROTECT OR DETECT VIRSUSES, MALWARE, SPYWARE, ETC IN EXECUTABLES.
sorry. it just does not work that way. for executables, it never has. if it did, then (for example) Sony could not have installed rootkits on so many computers.
ER10 awaiting restoration
In that I have no desire to insult anyone and clearly am not intelligent enough to follow the twists and turns of this discussion I shall move on to some other worthy subject.iclark wrote:...and your elected federal officials should uphold the Constitution (as they are sworn to do),:(
F. Jim Parks
Lakewood, Colorado:)
TiteBond III used
I used TiteBond III used ( http://www.shopsmith.net/forums/showpos ... ostcount=1 ) to avoid the cleanup problem associated w/both GG (urethane) and CA. I can say that it worked but can't compare it to the other glues.
