Casting ID help needed
mikelst
Post by mikelst »
I tried posting this on my rebuild update page but got no replies. I thought If I asked as part of a new thread I might get a better response so please forgive the duplicate post.
I have a question about my base and headrest. I read recently that the base and headrest assembly's were different on the older 1 7/8" base tubes. Something about some cast spacers??? I have those tubes but... I'm not sure I painted the right castings. I have some spares around here and I may have grabbed them by mistake. Can you look at these pictures and tell me if I have the right castings painted???:confused:
These are the ones I have painted.
http://www.shopsmith.net/forums/attachment.htm?attachmentid=8409&d=1270513196
http://www.shopsmith.net/forums/attachment.htm?attachmentid=8410&d=1270513201
I think they are the right ones but?
Thanks for you help
Mike......... Rowlett, Texas, near Dallas
86 MK V 500/520. 59 MK 5 Greenie Shorty. SS Jointer, SS Planer,
SS Bandsaw, SS Lathe duplicator, SS Belt Sander,SS Molder & Shaper,
SS Tenon master jig, SS Mortising kit, SS 2 1/4' Drum Sanders, Ringmaster, DC3300....
The pix appear to be the 1 7/8" variety! The 1 3/4" variety have a small projection on the casting surface the tubes press against. This projection is only 1/16" that realigns the smaller tubes to the center to center distance and the center of those holes into which the tubes 'go'. I looked for a pix, but have not found it. I think it may be buried in mickyd'd Greenie rebuild thread.
heathicus
Post by heathicus »
JPG40504 wrote:The pix appear to be the 1 7/8" variety! The 1 3/4" variety have a small projection on the casting surface the tubes press against. This projection is only 1/16" that realigns the smaller tubes to the center to center distance and the center of those holes into which the tubes 'go'. I looked for a pix, but have not found it. I think it may be buried in mickyd'd Greenie rebuild thread.
This the pic you're looking for? :D
[ATTACH]5077[/ATTACH]
Heath
Central Louisiana
mickyd
Post by mickyd »
You talking about the thread YOU posted maybe??
https://forum.shopsmith.com/viewtopic.php?t=3589&highlight=casting+tube
Sunny San Diego
mikelst
Post by mikelst »
Thank you all for your help. It appears I grabbed and painted the right castings after all. Probably used all my luck for the year on this one.:D
mickyd wrote:You talking about the thread YOU posted maybe??
BINGO!!!
