brain dead caster assembly
trying to throw casters back together on 10E project. For some reason, after a long day at work, the brain is not making the connection with the hands to get the cams and actuating lever in synch. Is there a simple way to look at it? I purposely left the other set assembled and it has been too long of a day for me to figure it all out. Any quick hints will be appreciated for when I attack it tomorrow
Maybe this will help:
http://www.shopsmith.net/forums/attachment.htm?attachmentid=8217&d=1269113950
Keep in mind the top one is incorrect. The shaft should be flipped end for end, and the footpedal on the opposite end.
