calibrateing the speed
hagarz71
Post by hagarz71 »
A few months ago I cleaned the dial as it was difficult to turn, and of course upon reasembling I managed to misalign it and now at my slowest setting it stops at E or F. Now im kind of gunshy at taking it apart and trying to fix it for fear that i may make it worse. But it has to be done, so any information will be much appreciated.
Homer Garcia
Crestview, Florida
hagarz71 wrote:A few months ago I cleaned the dial as it was difficult to turn, and of course upon reasembling I managed to misalign it and now at my slowest setting it stops at E or F. Now im kind of gunshy at taking it apart and trying to fix it for fear that i may make it worse. But it has to be done, so any information will be much appreciated.
No need to be gun shy. View this and if it doesn't answer all your question come back here with more.
beeg
Post by beeg »
You can download this for future use.
[ATTACH]8476[/ATTACH]
how to do a high speed adjustment.PDF
(382.25 KiB) Downloaded 957 times
ldh
Post by ldh »
hagarz71,
Take a look at the site SONG OF THE NORTH WOODWORKING and you will find an excellent procedure for setting the speed dial as well as a couple of little tools you can make to make it even easier.
ldh
ldh wrote:hagarz71,
ldh
Is it possible that you are talking about this site?
hagarz71
Post by hagarz71 »
thanks for the information guys, I figured i wasn't the first or will i be the last to to this.
Homer Garcia
Crestview, Florida
hagarz71
Post by hagarz71 »
My speed dial is right on the money now. My first attempt was not so good as i had some grinding when speed raised to high. So I went back and rewatched the video again and good as new. thanks again.
Homer Garcia
Crestview, Florida
hagarz71 wrote:My speed dial is right on the money now. My first attempt was not so good as i had some grinding when speed raised to high. So I went back and rewatched the video again and good as new. thanks again.
Thank you for reporting back with word of your success. I assume your problem was resolved simply by getting everything set correctly. This is not uncommon. The Shopsmith just keep plugging along. About all you need is wax and oil.
