In a thread about adding a drill sharpener to the SS, I show a base made of wood. I also wanted to make use of several 7" diameter grind stones that I have. The wood base can also support a Lee Valley work rest. To install the grind stone shield, I started with the drawing in PTWFE of the buffer shield and modified it to give access to the set screw of the universal arbor I used to mount the stone. The shield is about 8" in diameter. The shield is screwed to pieces cut from a 2x6 and 1/2" plywood and mounts to the quill. It can be rotated to expose more or less of the stone. Please see attached photos.
[ATTACH]8707[/ATTACH]
[ATTACH]8708[/ATTACH]
[ATTACH]8709[/ATTACH]
[ATTACH]8710[/ATTACH]
[ATTACH]8711[/ATTACH]
mounting a 7" grindstone on a SS
- grinder shield 1.jpg (61.85 KiB) Viewed 5916 times
- grinder shield 2.jpg (98.22 KiB) Viewed 5886 times
- ready to mount stone.jpg (125.68 KiB) Viewed 5890 times
- seen from back to show access to set screw.jpg (88.73 KiB) Viewed 5887 times
- stone and rest 2.jpg (93.88 KiB) Viewed 5886 times
Peter
Here are a few more pictures.
[ATTACH]8712[/ATTACH]
[ATTACH]8713[/ATTACH]
[ATTACH]8714[/ATTACH]
(edited to show pictures in the message)
- stone and rest mounted.jpg (101.14 KiB) Viewed 5851 times
- ready with light.jpg (100.48 KiB) Viewed 5844 times
- work rest.jpg (94.24 KiB) Viewed 5850 times
Peter
Kudos, Peter!:D and an ATTA BOY!!
You are a much better machinist than I. Would liked to have figured a way to do what you did, but settled for the Shopsmith grinding attachment and bought just the tool rest portion of the Lee Valley rest. I'll post a photo one of these days.
- cincinnati
The drawing is on page 150 in the hard cover PTWFE book under "Finishing Metal". I do not know if it is in the on-line copy.
Thanks to Charlese for your note. I also have the SS guard for the 5" stones but I had 3 of the 7" ones in various grits so wanted to have them usable too.
Peter
