Shopsmith planer
Shopsmith planer
I have to change the blades of my planer, I have the blades ready to be replaced but I found a very difficult obstacle, when trying to unscrew one of the set screws that hold the blade in place, I have used a considerable torque to unscrew it and it looks like it is welded I dont want to break anything applying brute force and I ask for help if somebody knows how to soften this little set screw .
Have ya tried some penetrating fluid on it yet?
shopsmith planer
Is WD-40 considered penetrating oil? Yes I have used it and nothing happened still the same stubborness, some body told me to use heat with a torch but I am reluctant to do it in my planer, it is a very good planer.
mbcabinetmaker
Lecu
WD-40 is not the best penetrating fluid. Try some PB Blaster from Lowes or better yet some Gibbs. http://www.getgibbs.com/
Mark
2017 Power Pro Mark 7
Mark
- mickyd
My local Home Depot carries it also.mbcabinetmaker wrote:Lecu
Sunny San Diego
Sunny San Diego
shopsmith planer
okie dokie, will try And see what happen hope it work because I feel I am in a dead end with this set screw
Thank you much
Thank you much
Heath
Central Louisiana
Central Louisiana
heathicus wrote:
Cost effective alternative!:D
[ATTACH]8836[/ATTACH]
Adding acetone and shaking vigorously(a mixture in a smaller container) may speed it up! Patience IS a virtue!
Are you acquainted with an 'impact driver'.
http://www.harborfreight.com/7-piece-re ... 93481.html
- two thumbs k1.jpg (126.81 KiB) Viewed 6184 times
Loved the pictorial responses
You guys crack me up!! The pictorial plug for Kroil, followed by the "tow thumbs up" rebuttal was EXCELLENT!! I needed that laugh, and agree with both suggestions.
I am just curious, how long has that can of kerosene been in the family?:DJPG40504 wrote:Cost effective alternative!:D
http://www.harborfreight.com/7-piece-reversible-impact-driver-set-93481.html
Rob in San Diego
