Belt sander repair question...
easterngray
Post by easterngray »
Can anyone tell me what the proper orientation of the rectangular bushings and the eccentric cams are in relation to the housing on the belt sander idler drum shaft ends? I just installed new bushings and want to reassemble it properly. FYI for anyone consideringreplacing these bushings as well - the roll pin at the end of the shaft is a real "bear". I almost wish I had bought a whole new idler drum assembly! Thanks in advance - Alec
mikelst
Post by mikelst »
Not sure if it is here but... I seem to remember Nick took the beltsander all the way down and rebuilt it in this sawdust session
http://www.shopsmithacademy.com/SS_Arch ... Tuneup.htm
Maybe it has the info you need in it.
Hope that helps
Mike......... Rowlett, Texas, near Dallas
86 MK V 500/520. 59 MK 5 Greenie Shorty. SS Jointer, SS Planer,
SS Bandsaw, SS Lathe duplicator, SS Belt Sander,SS Molder & Shaper,
SS Tenon master jig, SS Mortising kit, SS 2 1/4' Drum Sanders, Ringmaster, DC3300....
easterngray
Thanks Mike - I hadn't had the cams aligned properly, so that was a big help - thanks again - Alec
