pen turning books
pen turning books
I recently looked over the pen turners workbook by Barry Gross does anyone have any suggestions or comments about this book? If anyone has this book please let me know if its worth the money.Also fill me in on any good pen turning books by different authors.
Another Pen Truning Book
I am unfamliar with the book you mentioned. However I just finished reading the most comprehensive Pen Truning book I have found to date. Check out "Turning Pens and Pencils":) by Kip Christensen and Rex Burningham. I purchased it at woodturningz.com. Jim Parks
Unregistered
Forget the books, they are unnecessary. You can buy Hot Shot glue with your money instead. Pen parts are standard, only the wood is different. If you are planning on making oak pens, use white oak as it holds together on the lathe. You dont have to worry if your bore hole is not straight in the wood block, nor do you need to be concerned that your wood blocks are square. Just make sure the length is accurate.
