Speed settings on the Shopsmith
No name
Post by No name »
Does anyone know as far as the dial you use to adjust the speed on your Shopsmith the rpms of each setting. I do know it is about 700 rpm on slow and about 3000 on high. So does that mean about half way is 1500 rpms?
Speed Chart
Attached is a copy of a Speed Chart provided by another member of this forum.
Shopsmithspeed2.doc
(21 KiB) Downloaded 2911 times
Bruce
Post by Bruce »
No name wrote:Does anyone know as far as the dial you use to adjust the speed on your Shopsmith the rpms of each setting. I do know it is about 700 rpm on slow and about 3000 on high. So does that mean about half way is 1500 rpms?
Actually, I think the high speed is 5200 rpm.
There is a speed chart in the "Father's Day" Shopsmith Catalog on page 33. Yes High speed is 5,200RPM, L = 2,000 and M = 2,400RPM.
