Yesterday we drove down to Ft Myers, and picked up a "Greenie mini", with an extension table..
I believe the power head is a 1956.
It's in pretty good shape. Original 3/4HP motor, and "gilmor belt".
It runs up and down smoothly, and it's not noisy.
The guy I bought from said the prior owner rebuilt it. It does have a new power cord. The insides are very clean.
This has a access hole, and a spring held cover plate, the same as my 1973 MKV. I don't know if this was original, or was modified?
The guy I bought it from had started to paint it. He got the legs, and ends painted.
The only problem I see so far is that when he reassembled the foot levers on the casters, he installed them backwards!!
I plan on using this just for the band saw, and belt sander.[ATTACH]10117[/ATTACH]
Newest addition to the "Magic Garage".
- shorty 2.jpg (23.73 KiB) Viewed 2924 times
mbcabinetmaker
Regarding assembling the wheel assembly backwards. I have been known to do that intentionally. In my last shop I had a space issue and discovered that was the best way to set up one of my 520's. fjimp
F. Jim Parks
Lakewood, Colorado:)
What says that one way is incorrect (backwards) and the other is correct? Mine are not all the same. Does that mean some of them are WRONG?:rolleyes:fjimp wrote:Regarding assembling the wheel assembly backwards. I have been known to do that intentionally. In my last shop I had a space issue and discovered that was the best way to set up one of my 520's. fjimp
The foot pedals on the mini are on the shaft 'upside down',:eek: not backwards. Foot pedals in front or rear is a matter of personal preference.dusty wrote:What says that one way is incorrect (backwards) and the other is correct? Mine are not all the same. Does that mean some of them are WRONG?:rolleyes:
