Most creative Shopsmith mods or jigs?
damagi
Post by damagi »
Just curious to see what mods or jigs people have put together for their shopsmiths.
A few that looked pretty cool to me:
http://www.hicklerbanjo.com/shopsmith_mod.html
http://www.shopmachineadventures.com
http://backyard-workshop.com/projects/m ... lathe.html
I also saw in an old ShopNotes that somebody had adapted their photography enlarger to work on the shopsmith way tubes...pretty cool.
Though not specifically shopsmith, the stuff on http://woodgears.ca/ is pretty cool.
shipwright
Post by shipwright »
I take no credit but I have these (as most of you already know) with my 10ER.
[ATTACH]10318[/ATTACH] [ATTACH]10319[/ATTACH]
Just wish I could find a bandsaw nearby to use the spt mount.
Paul M
damagi
Post by damagi »
http://armchairdiy.com/making-modifiyin ... uter-plans
I love the idea of the OPR, but before I invest in the shopsmith branded one I would definitely consider a DIY version like what Popular Mechanics did back in their February 1997 issue. Theirs is for a single post drill press, but adapting to the shopsmith's dual post design would be simple enough.
derekdarling
SS Jigs
Post by derekdarling »
Not mine, but a local piano repair shop has this to shave piano hammers to the precise width:
[ATTACH]10329[/ATTACH]
[ATTACH]10330[/ATTACH]
I understand these are available for piano repair shops. Lovely piece of work, uses UHMW plastic.
He has 2 10ERs, one for horizantal work, and one for drill-press work, and inherited them (and the shop) form his Dad.
Derek in Surrey, BC
Derek Darling
Surrey, B.C. Canada
10ERs, other stuff, you know.
nuhobby
Post by nuhobby »
When I first was using the Mark-V, I was too impatient to make any jigs.
As time went on I was pretty happy to make some jigs even if I used them only once...
A home-made "Sand Flee":
http://www.shopsmith.net/forums/attachm ... 1217464621
A multi-adjustable bandsaw Resawing guide:
http://www.shopsmith.net/forums/attachm ... 1207933921
A pretty strange Fluting jig which made one nice screwdriver, but I didn't use again. Others have posted much nicer fluting/routing methods, using for instance small trim-routers well-attached to the tool-rest post:
http://www.shopsmith.net/forums/attachm ... 1225671909
Chris
truxton
Shopsmith Frame Jig
Post by truxton »
I am planning a new jig from a Shopsmith VII frame. I purchased the 2 end castings on E-Bay from a VII for $35. The VII has four way tubes held by the end castings. With the frame set up with out the head stock I will have 2 places to mount the add on tools, band saw and belt sander with belt driven motors. The 2 top way tubes I could have a bearing slide that would either hold a skill saw or a router to make cross cuts. I need to get 4 way tubes a little over 4' so i can cross cut 4' x 8' sheets of plywood. Much like a panel saw or like the old delta saw buck with the capacity of the dual arm saw. With the right under frame and sturdy bearing slide I could also mount my chain saw to slab 4' logs. Any thoughts? I would love to hear your opinion on this jig idea.
shipwright
damagi wrote:http://armchairdiy.com/making-modifiyin ... uter-plans
Any particular reason you need the router on top? There are good reasons to invert the process like I did here: http://www.shopsmith.net/forums/showpos ... stcount=22
Paul M
Shoestrings
Re: Most creative Shopsmith mods or jigs?
Post by Shoestrings »
I like the lathe duplicator you could post more photos.
Would be fun to make that jig
