Speed Dial is too stiff
ctxman
Post by ctxman »
Hi all,
I just picked up a used 510, mostly to create a sanding station with the disk and belt. Overall it looks pretty clean, even inside the headstock. The speed dial however is very tight as I try to run it, and it even feels like it's got interference and is rubbing or almost grinding. In fact I can't seem to get it to go into the highest speed. Everything I've read or watched on video so far talks about making adjustments but they all start off with putting it into high speed. Is there a way to do it besides using the dial? Any ideas on what is making the dial so stiff?
Appreciate some help. Thanks
ctxman wrote:Hi all,
Three Things!
1) Lubrication(lack of) Quadrant gear (dry lubricant) graphite etc
2) Lubrication(lack of) Control sheave (#10 oil) sewing machine/turbine/3 in one
3) Lubrication(lack of) Floating sheave (#10 oil) """
The third one is the most likely and the first is the least likely. They ALL need constant(every 10 hrs) attention.
A belt or belts could also be sticking to the face of the sheaves.
Inspect the sheaves to make certain that they are clean and smooth (where the belts ride).
allsas
Look for Achy-Punky compacted in the Gears.
Post by allsas »
Lubrication will help, but the difficulty in getting the Speed Control to turn may be compacted Wax and sawdust in the gear gullets. The worm gear and Quadrant may have filled with compacted sawdust and needs to be forcefully cleaned. Same with the shafts: if the previous owner did a lot of sanding the dust may have accumulated on the shaft, adding oil (lubrication) is causing the dust to soak up the oil and make the sheaves harder to move. It needs to be CLEANED, not just lubed.
A Goldie ,indicating some use, had a Quill that wouldn't extend far enough to be removed. It was filled with HARDENED wax/sawdust that had to be scraped out of the Advance Assembly Pinion and Quill Teeth. The Quill was soaked with Liquid Wrench for two days and the under belly of the quill wasn't still full of hardened Wax/sawdust. Same with the Table Height pinion and teeth on the table legs. At least somebody used the machine.
MK V 520; MK V 510 w/PP DIY Upgrade; MK 5 500; Jointer; Bandsaw; Sliding Table; Conical Sanding Disk; Sharpening Guide, Lathe Duplicator, Jigsaw, Scrollsaw, Beltsander, Ring Master, Biscuit Joiner.
ctxman
Post by ctxman »
I cleaned everything real good. There was gunk in the porkchop gear. Took it all apart, cleaned and lubed and now everything is fine. The control handle gear has a couple bad teeth on it that causes a little stickiness along a couple points - i'll either replace or live with it since I mostly bought this to be a sanding station and won't be changing speeds a lot.
Thanks all for your help.
SDSSmith
Post by SDSSmith »
ctxman wrote:I cleaned everything real good. There was gunk in the porkchop gear. Took it all apart, cleaned and lubed and now everything is fine. The control handle gear has a couple bad teeth on it that causes a little stickiness along a couple points - i'll either replace or live with it since I mostly bought this to be a sanding station and won't be changing speeds a lot.
There is a fellow in Whittier, CA who repairs these speed control dials. I have had a number of them repaired by him with excellent results. The repaired dial has steel gear teeth which are less likely to strip. He regularly offers this service on Ebay. I have contact information for him if he isn't running an auction.
Rob in San Diego
mhn1957
Post by mhn1957 »
SDSSmith wrote:There is a fellow in Whittier, CA who repairs these speed control dials. I have had a number of them repaired by him with excellent results. The repaired dial has steel gear teeth which are less likely to strip. He regularly offers this service on Ebay. I have contact information for him if he isn't running an auction.
I also HIGHLY recommend the guy. :)
Mark
Mark
8 miles north of the Ohio River, near Portsmouth, Ohio
Shopsmith Mark V (SS-68425)
bandsaw(SS-28617), jigsaw, 4 inch jointer, belt sander
mhn1957 wrote:I also HIGHLY recommend the guy. :)
Mark
I have acquired one rebuilt(I assume by him) in a grab bag of parts. It is well done!
shipwright
Post by shipwright »
Mark
Me too. Very nice improvement on the OEM part.
Paul M
ctxman
Post by ctxman »
Interesting...does anyone have a picture of this modification/upgrade so I can see what you are talking about?
