Sanding a log?
fiatben
Sanding a log?
Post by fiatben »
I need to clean up the end of a log (several actually) after chainsawing the end square to the log's run. Any one have an easy way to get a nice finish on the end of a reasonably dry (tree was standing dead for awhile) log end? Some way that doesn't require some expensive tool I do not have, something I can afford to do?
Thanks guys!
fiatben wrote:I need to clean up the end of a log (several actually) after chainsawing the end square to the log's run. Any one have an easy way to get a nice finish on the end of a reasonably dry (tree was standing dead for awhile) log end? Some way that doesn't require some expensive tool I do not have, something I can afford to do?
Thanks guys!
Belt Sander (hand held).
fiatben
That's what I was thinking,
Post by fiatben »
guess I need to go buy one. Sad to think of a wannabe woodworker who doesn't own a decent hand-held belt sander, huh? I've got a nice little bench model but don't see me trying to hold it upside down and getting a good finish. haha
SDSSmith
Post by SDSSmith »
Curious, what are the diameters of the logs?
Rob in San Diego
fiatben wrote:... Any one have an easy way to get a nice finish on the end of a reasonably dry (tree was standing dead for awhile) log end? Some way that doesn't require some expensive tool I do not have, something I can afford to do?
Thanks guys!
Perhaps you can use a bench vice to hold the log, or build a frame around it that will hold it. Then you could use a hand held belt sander.
shipwright
Post by shipwright »
I've never been a fan of hand held belt sanders myself, I always used to get belt edge gouges that ended up with the piece getting thinner and thinner. That was a long time ago however it was enough to send me down the disc sander road. I guess one reason is that you can smooth a wooden hull very quickly with an angle grinder. Once you get the hang of them they can do magic and if you follow up with a random orbital sander you never have to mess with belt sanders again.... so I never did. If it were me I would use an angle grinder with a fiber backing disc and I think the discs I use are called "Greenback". I could check if you were going that route.
Paul M
fiatben
big AND bigger
Post by fiatben »
SDSSmith wrote:Curious, what are the diameters of the logs?
15 to 30+ inches in diameter, sycamore (soft), standing dead for about 2 years until I cut it down 2 weeks ago
mickyd
Post by mickyd »
fiatben wrote:15 to 30+ inches in diameter, sycamore (soft), standing dead for about 2 years until I cut it down 2 weeks ago
So what are you making fiatben?
Sunny San Diego
mickyd wrote:So what are you making fiatben?
Sawdust!!!!!!!!!:D
shipwright wrote:I've never been a fan of hand held belt sanders myself, I always used to get belt edge gouges that ended up with the piece getting thinner and thinner. That was a long time ago however it was enough to send me down the disc sander road. I guess one reason is that you can smooth a wooden hull very quickly with an angle grinder. Once you get the hang of them they can do magic and if you follow up with a random orbital sander you never have to mess with belt sanders again.... so I never did. If it were me I would use an angle grinder with a fiber backing disc and I think the discs I use are called "Greenback". I could check if you were going that route.
Paul M
Since you were sanding convex surfaces(asymmetrical curvature) I can well understand your frustration with belt sanding(designed to create flat surfaces).;)
