Motor question
trevsay
Motor question
Post by trevsay »
I am a fairly new SS owner. Bought V about a month ago. Works fine in the E-H power range but when I configure to use table saw motor loses power. At times it will catch and start to spin again but when I put wood to the blade it stops. Sounds like the motor is running fine. Bad belts? I took apart headstock and removed main drive belt. Powered up motor and it runs fine. Any one have any ideas on where to go next. Thanks!
Trevor
Sierra Vista, AZ
trevsay wrote:I am a fairly new SS owner. Bought V about a month ago. Works fine in the E-H power range but when I configure to use table saw motor loses power. At times it will catch and start to spin again but when I put wood to the blade it stops. Sounds like the motor is running fine. Bad belts? I took apart headstock and removed main drive belt. Powered up motor and it runs fine. Any one have any ideas on where to go next. Thanks!
Trevor
Sierra Vista, AZ
Lubricate the sheaves shafts.
#4 #11 are relevant.
http://www.shopsmithacademy.com/Sawdust_Sessions.htm
