Mystery Parts
damagi
Mystery Parts
Post by damagi »
[ATTACH]10801[/ATTACH]
Anyone know what this is? The set screws are 5/32. the two pieces were bolted together in the box of misc parts.
Thanks
Mystery parts.jpg (93.75 KiB) Viewed 3222 times
damagi AT gmail DOT com
damagi
Post by damagi »
More mystery parts:
[ATTACH]10803[/ATTACH]
[ATTACH]10804[/ATTACH]
[ATTACH]10805[/ATTACH]
[ATTACH]10806[/ATTACH]
damagi
Post by damagi »
[ATTACH]10807[/ATTACH]
[ATTACH]10808[/ATTACH]
[ATTACH]10809[/ATTACH]
Found the patent for this one:
http://www.docstoc.com/docs/42792499/Wo ... iewer-area
Looks like a lathe tool that creates its own toolrest
lathe tool 1.jpg (81.58 KiB) Viewed 3198 times
lathe tool 2.jpg (66.9 KiB) Viewed 3197 times
lathe tool 3.jpg (42.92 KiB) Viewed 3205 times
Mysteries indeed!
The last items if stainless steel(questionable) might be medical. edit-ignore this, I just noticed the patent link. :>{{
Is the x shaped thing jointed. If not are the intersections square?
BTW What is a 5/32 screw??? 10-32 maybe???
Anybody recognize a 247 Model 10E subassembly id#?
RobertTaylor
Post by RobertTaylor »
the x shaped thing is a machinist's v-block. got one just like it.
damagi
Post by damagi »
JPG40504 wrote:Is the x shaped thing jointed. If not are the intersections square?
The intersections are square.
JPG40504 wrote:BTW What is a 5/32 screw??? 10-32 maybe???
There are two set screws that accept a 5/32 allen wrench. they secure the hole is 3/4"
cw_1821
Post by cw_1821 »
damagi wrote:More mystery parts:
The rectangular bar with the channel running down the center and an oddly shaped hole in the top is a jig used to mount the saw blade to the lower blade holder on older model RBI scrollsaws.
damagi wrote:The intersections are square.
The screws are probably 5/16-18 then. Those parts are larger than I initially perceived! Still no clue!
