I am rebuilding a 1980 Mark 5. I have removed the disc paper from the disc and have tried alcohal and minerial sprites to get the glue off with no success. does any one have any other ideas? Thanks; Ray
p.s. every is working fine after 15 years of sitting, I'm ready to build desks for the grandkids.
Disc sander cleaning
[quote="flyray"]I am rebuilding a 1980 Mark 5. I have removed the disc paper from the disc and have tried alcohal and minerial sprites to get the glue off with no success. does any one have any other ideas? Thanks]I hope that everything got a good cleaning and lubrication before being put back to work.
With regard to the sticky sanding disk: heat may be your solution. Here in Tucson I would set it out in the sun. Depending on where you are, that might not work. A hot air gun or the kitchen oven, set at about 200 degrees, should work.
Glue removal
I tried just about everything I could think of to remove the window tint residue from a car and believe it or not the best thing was Fantastic household cleaner. It was fantastic! sic
