Motor question
redrock
Motor question
Post by redrock »
I just changed belts on a used Mark V every thing related to that seems OK. I just bought the machine used and it was noisy and with the age I figuared it couldn't hurt to take it apart clean it and change the belts. Easy enough. Here is the problem the fan sheave is rubbing on the sheet metal fan cover behind the fan sheave. It is very loud and I am sure it isn't susposed to do that. Is there a way to get to the cup set screw is my question. Is it user serviceable? The sheet metal fan cover appears to be riveted to motor front. From the blown up parts picture it appears that the cup set screw is behind the fan cover or shroud. Any help would be appreciated. TY.
redrock wrote:I just changed belts on a used Mark V every thing related to that seems OK. I just bought the machine used and it was noisy and with the age I figuared it couldn't hurt to take it apart clean it and change the belts. Easy enough. Here is the problem the fan sheave is rubbing on the sheet metal fan cover behind the fan sheave. It is very loud and I am sure it isn't susposed to do that. Is there a way to get to the cup set screw is my question. Is it user serviceable? The sheet metal fan cover appears to be riveted to motor front. From the blown up parts picture it appears that the cup set screw is behind the fan cover or shroud. Any help would be appreciated. TY.
1) There is a spacer on the shaft that spaces the fan sheave away from the motor. It can get damaged if the floating sheave is allowed to bang against the fan sheave(like pulling it out and it slips and the spring slams it into the fan sheave).
2) The set screw is accessible through a hole in the bottom of the motor pan.
This may require replacement of the spacer!:( That would require removal of the floating sheave spring!:(:(
redrock
Post by redrock »
Thank you for the reply. I was going to take the motor off tomorrow and see what there is to see I was worried when I saw the rivets. I will see what can be done then. Thanks again.
beeg
Post by beeg »
See if this PDF helps ya.
[ATTACH]11247[/ATTACH]
the fan sheave rubbing motor-plate repair.PDF
(118.2 KiB) Downloaded 499 times
beeg wrote:See if this PDF helps ya.
Gotta think a washer would rube goldberg fix this!(between the spacer and fan sheave)
redrock
Post by redrock »
The Rube Goldberg idea sounds like a plan to me. I will post a msg. once I see what I can do tomorrow. That temp fix sounds like it would work.
stew
Post by stew »
This exact same thing was happening to me. After taking it apart and back together several times and still the rubbing sound. I then looked very close at the fan sheeve and saw that it had split and that my key was really bent. I replaced the fan sheeve and key and everything is running great now. See pictures of crack/split right where the key goes.
redrock
Upate
Post by redrock »
I took the fan sheave off today. The cup set screw was loose but to be sure I used the Rube Goldberg approach installed a washer put some thread tightener on the set screw and the Mark V is running great. I am doing the alignment now then setting up to do some lathe work. Thanks for all the help. This forum is great very helpful group. Merry Christmas and Happy New Year to all.
redrock wrote:I took the fan sheave off today. The cup set screw was loose but to be sure I used the Rube Goldberg approach installed a washer put some thread tightener on the set screw and the Mark V is running great. I am doing the alignment now then setting up to do some lathe work. Thanks for all the help. This forum is great very helpful group. Merry Christmas and Happy New Year to all.
With it up and running(quietly) I am sure yours will be!
