using an E for a joiner
terry glenn
Post by terry glenn »
I have a rebuilt 10er, and have the joiner fence. I cannot find any pics of the proper set up, to use this as a joiner.
Any and all help is greatly appreciated.
Thanks and MERRY CHRISTMAS to all
Terry
Learning as fast as I can
etc92guy
Post by etc92guy »
Hi Terry,
The fence needs some additions. :D The setup for the joiner 10e/er is vastly different than the Mark V. As I recall, the way tube bracket on the motor pulley end of the 10 er is replaced with one that comes with the joiner. The joiner bed is hung from the bracket. The headstock is then slid close to the new bracket. The joiner can then be swung up and is held in place by the belt that is on the joiner and motor pulley. Your fence then goes on the joiner bed.
I think you need more pieces........
Craig
Hartland, WI
-Mark 5 "Greenie" S/N 342238, Manuf. mmm/mmm 1957, Acq. Oct. 2008, Joiner S/N M067266
-10 E/ER(?) S/N Unknown, Joiner 4E S/N 40051
SDSSmith
Post by SDSSmith »
See if this file helps.[ATTACH]11320[/ATTACH]
10er shaper fence.pdf
(212.6 KiB) Downloaded 628 times
Rob in San Diego
billmayo
Post by billmayo »
etc92guy wrote:Hi Terry,
There was 2 different joiners made for the 10E/10ER. The above describes the later version which looks very similar to the MK V joiner and many of the Mark V joiner parts can be used on this later model.
I would believe you may have the earlier 2 1/2" joiner that has the cutter head attached to the quill. A picture of the fence would help determine which joiner you have.
