Hello? Is this thing on?
Ok, it works. . .
Hey everyone. Mark V owner here. It's in a hundred pieces at the moment, but coming together slowly.
Hello, Is this thing on?
Hello, to you too. Looking forward to what ever you might have.
Here we go. . .
Ok, I got everything categorized for easy reassembly.
[ATTACH]11693[/ATTACH]
Removing rust with electrolysis. I built a box for the bench tubes using someones method I found on this forum. I would love to credit him, but I forgot who it was. . .
[ATTACH]11694[/ATTACH]
Again, using someones method to polish the tubes.
[ATTACH]11695[/ATTACH] [ATTACH]11696[/ATTACH]
The tubes were damaged pretty bad because of the rust. The holes are about 5cm deep.
[ATTACH]11699[/ATTACH]
- 100_3106.jpg (30.51 KiB) Viewed 2681 times
- 100_3105.jpg (22.32 KiB) Viewed 2679 times
- 100_3109.jpg (30.61 KiB) Viewed 2520 times
- 100_3112.jpg (29.8 KiB) Viewed 2517 times
- 100_3108.jpg (26.26 KiB) Viewed 2680 times
agsmx wrote:Ok, I got everything categorized for easy reassembly.
MickyD
Heathicus
Wow! that is deeper than the od! 5cm is almost 2 inches! They look more like 0.5 mm.
