A Jawhorse Carving Stand.
cv3
Post by cv3 »
I do not know there are not many carvers here. But I needed a carving stand of some kind. Something that was portable and could be broken down and stored away. I also wanted a place to mount my Jerry Rig vise and holds the tools I am working with. Not long a go I got a Rockwell Jawhorse. I have been very happy with the way it works. It holds block lumber and logs very secure. I came up with this setup using the Jawhorse. I think will work well for me. It makes a very stable carving set up. I thought I would share it.
[ATTACH]11882[/ATTACH] [ATTACH]11883[/ATTACH]
[ATTACH]11884[/ATTACH] [ATTACH]11885[/ATTACH]
Jawhorse jig 1.jpg (173.99 KiB) Viewed 3163 times
Jawhorse jig 2.jpg (166.92 KiB) Viewed 3115 times
Jawhorse jig 3.jpg (130.09 KiB) Viewed 3121 times
Jawhorse jig 4.jpg (190.66 KiB) Viewed 3128 times
Make today a day that lets you smile!
CV
Mobile Al.
MARK V 520 - Band saw and Jointer. DeWalt scroll saw.
Nicely done! Do tell us about de blue de vise!:confused::);)
cv3
Post by cv3 »
[quote="JPG40504"]Nicely done! Do tell us about de blue de vise!:confused::)]
The blue de vise is a Jerry-Rig. It gives you the ability to rotate your carving or what ever is mounted on it 360 degrees and raise or lower the work. The vise mounts on a workbench or table. The other attachment that works like a little workmate and lets you work on small thing, I have use it for working on a lot of things.
[ATTACH]11888[/ATTACH]
Jerry Rig 2.jpg (198.46 KiB) Viewed 3104 times
CV
Mobile Al.
cv3 wrote:The blue de vise is a It is called a Jerry-Rig. It gives you the ability to rotate your carving or what ever is mounted on it 360 degrees and raise or lower the work. The vise mounts on a workbench or table. The other attachment that works like a little workmate and lets you work on small thing, I have use it for working on a lot of things.
I am sorry!!! I thought you were mis-spelling 'jury-rig'.:eek:
My bad! Gee the things you learn when you ask questions!!!!!:)
