Shopsmith greenie
Shopsmith greenie
Hi folks, I am new here so if I am in the wrong place, pardon.
I have conventional woodworking equipment but a small shop and have considered a shopsmith for a long time.
I have found a 56 model and the price, $300, seems reasonable. I watched the video and how to check out a machine but the unit is a ways away from my house so I am tyring to do a little research before I travel.
I know the model was originally equiped with one bearing in the headstock. I think the owner may have done some modifications because he said he changed the belts two years ago.
How critical is the bearing issue to quality, accurate cuts? Should I hold out for a newer machine?
All suggestions apprciated.
MGBOB;
Welcome to the forum. The two bearing quill will aid in putting the quill back in the headstock and does reduce the runout in the end of the shaft so it will improve accuracy but I think that it is minimal. The two bearing quill from SS will probably NOT work in a '56 because I think that the splines are different. To upgrade to a two bearing quill you will most likely upgrade from the Gilmer drive to the poly v drive and that will require changing more parts. It can be done but may be in the area of $300.
Please your profile to include your location. If you contact Bill Mayo on this forum and communicate with him privately he may be able to remachine your original quill to a two bearing quill.
mbcabinetmaker
Bob welcome to the forum.
I do not mean to discourage you as many here have the Greene's but if it were my money I would spend it on a later model with a 1 1/8 hp motor. The 2 bearing quill is nice but not a deal maker/breaker as I have a single bearing Mark 5 in my line up and honestly cannot tell the difference. The difference in the motor power would however be quite noticeable.
Mark
2017 Power Pro Mark 7
Mark
Location and stuff
Hi folks, I am in the Kansas City area. I am not sure that some work may have been already done.
I totally agree with what Mark has said. The quill bearings is not of itself an issue, but the 3/4hp motor and Gilmer drive is.
It is only an 'issue' because new gilmer drive parts are not available(gilmer belt excepted).
A 1 1/8hp Shopsmith motor is directly interchangible with the 3/4hp motor.
Another 'detail' is the Greenie(and early Goldie) is designed as a 9" saw, whereas the later Mark V are 10".
The most important 'virtue' is the mechanical condition.
mgbob,
A lot of user's here have single bearing quill greenies and are happy with them. I have a 55. $300 is resonable price for a well maintained machine, but before I made the trip I would want to know what accessories and special purpose tools he has for it. A picture would be beneficial.
Here are a couple of other questions to ask:
What is the serial number? (will help you determine age)
When he replaced the belts do he upgrade the machine from the Gilmer (cogged) belt to the Poly-V (ribbed) belt? (if he did it's definitely worth $300).
You could always offer $250 or less.
Sincerely,
Ron309753
Sincerely,
Ron309753
Condition, condition, condition. Oh and what 'extras(spt...)'?mgbbob wrote:All that being said what should I look for in price? I missed a 510 for about $500 and the greenie is about $300? Is that in the ballpark?
If this is the machine you are talking about I would not give him $300 or even $200. I don't see any acessories or SPT's! No miter gauge, no blade guard, no lathe centers, no saw blades, no sanding disk, no drill chuck? If that's all there is you would spend way too much money and time acquiring the pieces and parts you would need to make it useable.
http://kansascity.craigslist.org/tls/2238176320.html
Sincerely,
Ron309753
Sincerely,
Ron309753
Change your search on the Kansas City Craig's List to Shop Smith. You'll be surprised what pops up. I always check Shopsmith AND Shop Smith. Good luck.
Jayhawk
1982 Mark V 500 'Shorty' upgraded to 510 S/N 131846 (purchased new)
PowerPro S/N 09-02-10 (Sept 2010)
SS PowerStation, Bandsaw, jointer, belt sander, thickness planer, strip sander, lathe duplicator, ringmaster, jig saw, OPR
