Getting Blades Sharpend
I am setting up my Mark 5 that bought in the middle 80s up in Oregon.
I am looking to find out were I can get my blades sharpend in the Quartzsite Az. area. Can anyone give me info.?
Harry
osx-addict
I vaguely recall seeing a thread from someone a while back saying there was a mail order place you could send off to in Florida?? I don't recall.. Perhaps someone else will remember..hwestfall wrote:I am setting up my Mark 5 that bought in the middle 80s up in Oregon.I am looking to find out were I can get my blades sharpend in the Quartzsite Az. area. Can anyone give me info.?
Harry
Rick
S/W of Los Angeles, CA
1983 Mark V model 510 (SN#140061)
There are many places to get your blades sharpened but I send mine here. These folks are tried and proven.osx-addict wrote:I vaguely recall seeing a thread from someone a while back saying there was a mail order place you could send off to in Florida?? I don't recall.. Perhaps someone else will remember..
I use Scotts Sharpening Service
5214 W Luke Ave Ste 7 Glendale, AZ 85301
(623) 931-0633
A little ways from Quartzite, though. He does a great job on saw blades and jointer/planer blades, too.
(623) 931-0633
Gene
For What It's Worth
I realize you are looking for a sharpening service but if your in a bind, such as budgetary constraints or time (or just plain cheap), it is possible to sharpen a blade yourself.
I sharpened an original 9" SS combination blade that was completely rusted over and it cuts smoothly now, although I'm sure it would fair better if done professionally. I used a rotary tool (Dremel) with an abrasive wheel that was large enough in diameter (+/- 5/4") to get into the gullets without changing the angle of the hook.
However, this method doesn't take into consideration setting of the teeth. If they are misaligned (bent) I'm sure you'll get a sharp rasp, as opposed to a blade. Also, this method took me about two hours to complete and I had to hold my tongue just right.
Before
[ATTACH]12614[/ATTACH]
During - slot cut in 2x4 mounted to bench
[ATTACH]12612[/ATTACH]
After
[ATTACH]12613[/ATTACH]
How well does it cut? Some tear out on this cross cut red oak scrap.
[ATTACH]12615[/ATTACH]
Before
After
- IMG00037-20110309-2056.jpg (116.85 KiB) Viewed 2370 times
- Blade Sharpened.jpg (115.7 KiB) Viewed 2370 times
- DSCF1143.JPG (159.83 KiB) Viewed 2368 times
- IMG00064-20110309-2304.jpg (125.3 KiB) Viewed 2370 times
