Jigsaw blades
fiatben
Jigsaw blades
Post by fiatben »
Thanks to the generosity of a fellow forum member, I am now the proud owner of a Shopsmith Jigsaw (not scroll saw, I do know the difference). While I could spend time searching the forum and 'net for the information I need, I have things I need to be doing. So, I'm posting here to ask a very basic question:
What blade fits these old jigsaws, and where do I get them?
Thanks (in advance)
holsgo
Post by holsgo »
They are pinless blades and are on ebay all the time. You can also buy a pinned blade and grind off the pin if you are in a pinch.
peterm
Post by peterm »
It will take 4" to 5" blades per the manual found here:
https://forum.shopsmith.com/viewtopic.php?t=7404
thank you to those op's.
Peter
SDSSmith
Post by SDSSmith »
holsgo wrote:They are pinless blades and are on ebay all the time. You can also buy a pinned blade and grind off the pin if you are in a pinch.
Or you can drive the pin out of the blade easily.
Rob in San Diego
pennview
Post by pennview »
If you're planning to do fine work on the saw, like scroll sawing those intricate patters, you still want to buy SCROLL saw blades like these for the Shopsmith jig saw: http://www.scrollsawbladespatterns.com/
And not jig saw blades like these: http://www.milwaukeetool.com/accessorie ... saw-blades (although these also fit into the lower jaw/clamp of the Shopsmith).
Art in Western Pennsylvania
farley
Post by farley »
The best blades for scrolling I have found are Flying Dutchman.
http://www.mikesworkshop.com
Mike is super helpful with questions--he is going to have a hip replacement in May, so order before he get laid up.
moose
Post by moose »
You got that right Farley. I second that. Best scroll blade in the world hands down.
