Chuck adapter issue
cmccarter1
Chuck adapter issue
Post by cmccarter1 »
I use the PSI 1 x 8 adapter for my Mk5 and have been having problems with it loosing while in use. Anyone else had this issue? The chuck is a PSI 3000c
(baracuda4, i think)
michaeltoc
Post by michaeltoc »
I have a Barracuda, but have never had a problem with is loosening. Are you referring to the set screw on the quill or the threaded spindle adapter?
Michael
SDSSmith
Post by SDSSmith »
cmccarter1 wrote:I use the PSI 1 x 8 adapter for my Mk5 and have been having problems with it loosing while in use. Anyone else had this issue? The chuck is a PSI 3000c
If the set screw looks okay, I would put some blue loctite on the threads.
Rob in San Diego
cmccarter1
Adapter Loosening
It is the setscrew that appears to work loose after using it for a while. I'll try some loctite
cmccarter1 wrote:It is the setscrew that appears to work loose after using it for a while. I'll try some loctite
Make sure it is NOT red!
michaeltoc
JPG40504 wrote:Make sure it is NOT red!
Sounds like someone has a bit of experience with red loctite. HaHa!!! :D
Michael
michaeltoc wrote:Sounds like someone has a bit of experience with red loctite. HaHa!!! :D
No! I just happen to know better! Gained that knowledge right here!!!! I did not know there was any but the red before.
I have noticed many 'loctite' products since. Glue anybody?:D
FWIW, if the package seems light, check the 'tube' for proper contents prior to leaving the 'store'. That comes from 'experience'. I do not like getting home only to discover somebody/thing failed to fill the container!:mad:
