SPT build dates
jamiethesquid
SPT build dates
Post by jamiethesquid »
First off I promise to get some pictures posted this weekend and start a refirb/resto thread with my before and after pics.
So I am redoing a 1954 Mark 5 and want to determine the age of the 4"
Joiner and Magna Bandsaw, any help would be great.
Second, I am disassembling the Mark 5 and stripping the paint (which is black painted over the original green. After removing the way tube tie and power head. I want to remove the way tubes to polish them up as best as I can. One way tube was loose already and with a little wiggle came right out. The second one seems to be held in by it's set screw. Looking at the set screw it seems that the only way I will be able to reach it is if I remove the pivot pin. Which seems to be held in place by a roll pin. With a long Allen key I may be able to access the set screw but regardless I would like to fully disassemble to paint and resto. So how do I get this roll pin out. It seems like the only way to go is to drive it in deeper. Thanks
June of 1954, Mark 5, SN 271605
wa2crk
Post by wa2crk »
Jamie;
The set screw can be reached with the SS 5/32 allen wrench if you have one. If not then a long allen wrench should be available at most good tool retailers. As for the roll pin, I understand that it can be removed by using a pin punch and driving it in further until it drops out a hole in the bottom of the casting. My reservation is that this is OK for the newer machines but I am not very familiar with the greenie machines. A PM to Bill Mayo will get you the correct answer or you can wait for a few more posts here.
[quote="wa2crk"]Jamie]
Same since day one!:)
wa2crk
Post by wa2crk »
Good to know but I was not positive.
Bill
