555116 Disc Sanding Table Insert
rlkeeney
Post by rlkeeney »
Is anyone using one of these?
How is it better than using the edge of the table?
bffulgham
Post by bffulgham »
I would expect better dust collection.
Functionally, not much difference.
Bud F.
I see it simply as "another way" of doing the job. There are many processes that can be done in multiple ways. It is difficult to say one is better than the other.
I prefer to do this sort of task at the edge of the table - more top side table space.
Where did the image of that old 510 table come from?
8iowa
Post by 8iowa »
I usually use the insert for the disk sander with the lower saw guard for dust collection unless I need more table length. If using the lower saw guard, be sure to tighten the knob that secures the arm for the upper saw guard as it may rattle against the rear of the disk.
dusty wrote:I see it simply as "another way" of doing the job. There are many processes that can be done in multiple ways. It is difficult to say one is better than the other.
http://www.shopsmith.com/ownersite/catalog/images/DiscSanderTableInsert.jpg
keakap
Post by keakap »
rlkeeney wrote:Is anyone using one of these?
I'm guessing the Long slot is actually engineered (width) for better dust collection (and safety of course). If not engineered then incredibly lucky, 'cause dust collection is near perfect.
(of course for some applications open edge exposure is easier.)
SDSSmith
Post by SDSSmith »
I have one and use it occasionally.By closing off the top of the chute, I feel the dust collection is improved.I only have one because it came with a machine. Otherwise rather than buy, I would make one as I did for my conical disc (which I use frequently). With the conical used in the table like this, I can use my the magnetic scale on my 520 to quickly set the fence to size parts. As far as engineering goes......not sure. The regular sanding insert slot is wider and a little shorter than the standard saw insert.
Rob in San Diego
rlkeeney
Post by rlkeeney »
Dust collection. Duh, I should have thought of that.
stephen_a._draper
Re: 555116 Disc Sanding Table Insert
Post by stephen_a._draper »
I made one myself out of a blank insert that Shopsmith sells. I would like one of the original metal ones item #555116. Are any of you willing to part with yours?
stephen_a._draper wrote: Fri Jun 28, 2024 9:59 am I made one myself out of a blank insert that Shopsmith sells. I would like one of the original metal ones item #555116. Are any of you willing to part with yours?
I am sure Nick would be more than happy to 'part' with one. I am assuming they are still 'available'.
