?? Too buy a Biscuit Joiner or Mortise attachment ??
dauphin80
Post by dauphin80 »
Guys, please help me out. My tool budget only allows me to buy:
A) SS biscuit joiner
or
B) SS mortise attachment
What would you buy and why?
Thanks!
Rick
Hershey, PA
ShopSmith Mark V w/ Bandsaw, Jointer, & Belt Sander
SDSSmith
Post by SDSSmith »
dauphin80 wrote:Guys, please help me out. My tool budget only allows me to buy:
or
What would you buy and why?[INDENT] Thanks![/INDENT]
[INDENT]Is your budget based on new or used? New SS biscuit joiner for me is over $160 delivered];)
[/INDENT]
Rob in San Diego
Evidently, you will be needing to join boards and also make mortises. I'll recommend the biscuit joiner. You can already make very nice mortises with your Shopsmith. Use the horizontal boring position and a Shopsmith router chuck. You use the rip fence as a backup.
garys
Post by garys »
The Shopsmith does a great job of joining boards using dowels and its drill press capabilities. If you let the Shopsmith do your hole alignment, you should be able to get almost perfect results with what you already have, and the biscuit joiner isn't needed.
dauphin80
Post by dauphin80 »
Thanks guys for all the thoughts. It does give me something to think about!!
Rick
Hershey, PA
foxtrapper
Post by foxtrapper »
When it comes to biscuit jointing (or joining), I far and away prefer one of the hand-held units. They are cheaper and far more versatile than one that mounts onto a shopsmith.
Mortising works with the shopsmith, but there are some flex issues. Enough so even the instructor at the traveling school didn't particularly recommend it. Takes a goodly bit of force, pushing that chisel housing through the wood. That said, it didn't seem terrible to me. Yes, the dedicated ones are a bit better, but the SS wasn't horrible.
I'd go handheld biscuit jointer and ss mortising.
robinson46176
Post by robinson46176 »
foxtrapper wrote:When it comes to biscuit jointing (or joining), I far and away prefer one of the hand-held units. They are cheaper and far more versatile than one that mounts onto a shopsmith.
That is what I did. I acquired a SS BJ with one I bought, puttered with it a little and sold it. I have a Bosch BJ but if I didn't I would probably just buy a BJ router bit and use that. I am old fashioned enough that I like dowels too.
If you slip an extension table in the right end of the SS (in drill press mode) and put a simple support between it and the main table it will take about all of the flex out of the main table.
robinson46176 wrote:That is what I did. I acquired a SS BJ with one I bought, puttered with it a little and sold it. I have a Bosch BJ but if I didn't I would probably just buy a BJ router bit and use that. I am old fashioned enough that I like dowels too.
It being the edge of the extension table, or the mounting tubes?:confused:
swampgator
Post by swampgator »
charlese wrote:Evidently, you will be needing to join boards and also make mortises. I'll recommend the biscuit joiner. You can already make very nice mortises with your Shopsmith. Use the horizontal boring position and a Shopsmith router chuck. You use the rip fence as a backup.
Charles, this sounds like a great idea. But, I'm a bit slow on this concept. Do you have a pic on the setup? I just don't get the router chuck. That's my hold up. Thanks for your help.
Steve, the old Florida gator
I just love it when she says I can go make sawdust. ;) :D
robinson46176
JPG40504 wrote:It being the edge of the extension table, or the mounting tubes?:confused:
For me the edge of the extension seemed best. The closer the support is to straight up and down the less likely it is to make the main table try to move any direction as pressure increases.
YMMV :)
