in making a pendent, I want to off set the hole that the cord goes through.
I am having trouble starting that hole.
I have first rounded the outside and curved the face of the pendent, (on center) then I switch to offset,(eliptical) but starting the hole on the curved face of the pendent is resulting in much small scrap firewood.
You might try a center drill or a countersink cutter to locate the hole and then follow up with the correct sized drill bit. What diameter of hole are you drilling?
Troy
well the center of the hole is about 3/8" but since it's eliptical it should end up like a fat tear drop.
I am not sure I see what drilling would do? It's spinning on the lathe, maybe by drilling it first it will a least stay where I put the bit to start the hole.
I'm not following what you're doing, but perhaps if you drilled the hole first, then shaped the pendant, you'd have better success. If you could post a picture, we'd be better able to help.
Farley, after remounting the disk, use a pencil to locate the new center and outline the location of the hole you want to cut. That will show you where to cut the hole using a round nose scraper and skew, or small bowl gouge. If you can mount your drill chuck in the tail stock, you could also drill an appropriately sized hole and then clean it up with a skew used as a scraping tool. If not, locate the center and drill with a hand-held drill with the lathe turned off, then clean it up. Hope this helps, as that looks like a very nice pendant.
Hello In Feb. 2011 Woodturning Design mag. Bill Danahue made a pendant like you were talking about.
The hole was drilled after the pendants basic shape was made but before finnishing, in the artical.
Just thought that you would like to know.
Have a Great day.
C.A.G.
