Wet/dry grinder modification
OK, I give up searching the forum threads. Recently, pretty sure it was on here, I saw a modification a member made to his wet grinder using some clear tubing and a fitting. The modification acted as both a level and drain, depenting on the mounting of the tubing. I probably even saved a picture of it, but I can't find the picture or the thread. If someone recognizes this as theirs, or has a knack for finding back threads, I'd certainly appreciate it.
