Where to post it?
- Silver Member
Where to post it?
Is there a 'WANTED' section here I don't see?
Where should I post a specific need?
"Don't Be So Open Minded That Your Brains Fall Out"
1959 SS Mark V w/all attachments; 2 Craftsman 100 Table Saws; Delta 40-A Multiplex RAS; 6" Jet Jointer; Delta HomeCraft Floor and Bench Drill Presses; Dremel Everything; Rigid Dust Collector; and a vast collection of hand tools.
Something "WANTED" can be found here.
http://www.shopsmith.com/ownersite/index.htm
Other than that, your outta luck.
justplaingoofy wrote:Is there a 'WANTED' section here I don't see?
Try a PM to sdssmith or damagi or billmayo!
Then he needs a lumber yard or a hardware store, not a ss forum!:DSDSSmith wrote:What if he wants some wood? Or a source for hardware?
- RobertTaylor
- Silver Member
The SS Dado Blade that came with my SS is missing the two end blades and a couple of chippers. Does it have it's own special arbor?
yes, the dad blade needs a dado arbor.justplaingoofy wrote:The SS Dado Blade that came with my SS is missing the two end blades and a couple of chippers. Does it have it's own special arbor?
check your PM
damagi AT gmail DOT com
